Beaded Japanese 12-1 Bracelet - A great weave for the beginner – the beads add weight to the light bright aluminium jump rings.
You will need to choose rings that will accommodate a bead plus twelve joining jump rings. We have used bright aluminium rings but these can be easily substituted with anodised aluminium for a bit of colour or other metals such as copper or bronze.
For a 18cm bracelet, you will need:
- (A) - 24 bright aluminium jump rings ID 3mm, WD 1.63mm
- (B) - 135 bright aluminium jump rings ID 4.2mm, WD 1.29mm or use...
