Captive Inverted Round Maille - Capture rings in inverted round maille for a unisex chain with impact
Capture rings in inverted round maille for a unisex chain with impact - see the note on how to make this chain quickly once you have made your first one.
For a 21cm bracelet, you will need:
- 120 bright aluminium jump rings, ID 6mm, WD 1.02mm
- 44 bronze jump rings, ID 6mm, WD 1.02mm
- 12 bright aluminium small jump rings, ID 4.2mm, WD 1.29mm...
