Celtic Noughts & Crosses Cuff - Create a two-tone effect by using two contrasting colours in this easy chain maille cuff.
Create a two-tone effect by using two contrasting colours in this easy chain maille cuff, which also uses large square profile rings in the centre. The cuff is based on the Celtic Labyrinth unit by @Nárrína.
For a 17.5cm cuff, you will need:
- 128 black anodised aluminium saw cut jump rings, ID 4.2mm, WD 1.2mm - A
- 56 black anodised aluminium saw cut jump rings, ID...
