European 4-1 Cuff
European 4-1 Cuff - This weave is one of our favourites and was used for centuries in mail armour.
European 4-1 Cuff​
This weave is one of our favourites and was used for centuries in mail armour. The weave has a wonderful flow to it and can be shaped to create a wealth of designs. European 4-1 is an essential building block for a whole range of weaves.
Which rings?
You can use nearly any ring size, each creating a different result. The higher the aspect ratio is, the looser the weave, the lower the aspect ratio the more rigid it will become. Jump rings with an aspect...
