Atalanta submitted a new resource:
Aspect Ratio Chart (Letter and A4) - For those times when you don't feel like doing the math.
Since I decided to dust of my pliers and get back into maille, I wanted an easy way to figure aspect ratio. Now I know that to be perfectly accurate, you need to get out your calipers and measure the inside diameter of the ring and the wire thickness. Then take those numbers and plug them into the formula.
I went and did the math, assuming that things are often as they seem. So if you have the inside diameter and the wire thickness (or know the gauge and if it's SWG or AWG), you can look it...
