Glass Ring Ocean Waves
Glass Ring Ocean Waves - Make this stunning easy-to-make chain using glass rings with bronze in this mobius-based weave.
Glass Ring Ocean Waves​
Make this stunning easy-to-make chain using glass rings with bronze in this mobius-based weave. This is an adaptation of the Ocean Waves weave by 925maille.​
For a 17.5cm bracelet, you will need:
  • 40 large bronze saw cut jump rings, ID 10.4mm, WD 1.29mm
  • 44 ice blue anodised aluminium saw cut jump rings, ID 4.2mm, WD 1.2mm
  • 8 peridot Czech glass rings - 9.6mm...
